jims240 »
https://forums.nicoclub.com/jims240-u194328.html
Thu Dec 01, 2011 5:36 am
93 240sx with ka24de
I recently pulled the intake to replace all those hoses underneath.
Reassembled everything and the car runs great.
However, this is my problem.
When I torqued the intake, I used my inch/pound torque wrench. Using my calculator (to convert ft/lb to in/lb), I accidentally multiplied the ft/lbs by 16 instead of 12. I know, stupid mistake.
Anyway, Nissan manual calls for 12 to 14ft/lbs torque which converts to 144 to 168 in/lbs. Since I used 16 as the multiplier, this converts to 192 to 224 in/lbs. In error, I tightened the bolts to about 220 in/lbs (about 18.5 ft/lbs). So, the bolts are over-torqued by 52 in/lbs or roughly 4.5 ft/lbs.
I further researched the bolts, which are 8mm grade JIS 7. From info on the net, it appears the bolts can be torqued to 17.4 to 20.2 ft/lbs.
I used a new oem fiber gasket. I suspect it will compress some and may lower the torque values somewhat. On the other hand, when aluminum gets hot it will expand possibly increasing torque values.
I'm I over-analyzing?
What do you think? What should I do? Opinions, comments or bashing (I'm already mad at myself) are welcome.
Thanks for your input !!!
