DailyDrivers13 »
https://forums.nicoclub.com/dailydrivers13-u13728.html
Fri Feb 20, 2004 8:02 am
I think that using a fan for your FMI design would actually hinder air flow more then help it. With the Intake @ the front mouth of the car, nice and wide open, the suction @ idle is enough to pull in the ambient outside air w/o problems. When you're moving the amount of air raming the system itself should be porportionate to the speed of the car so in that sense, why would you even need a fan? Since permacool fans dont bend according to speed like your stock one then you'd probley hinder air flow with the fan blades. Outside air with or w/o the fan won't change a damn thing in regards to temperature either.
You talked about fan position as well. I don't think the position of the fan would matter since both puller and pusher fans are avalible.
I've seen a few of the FMI designs and unlike intercoolers, they seem to have a back wall, so your fan upgrade wouldnt do your intake any justice at all. With our without the intake upgrade, you cant go wrong with bigger injectors.
btw I'm using the 14" permacool puller. I know its CFM rating is double that of stock, it's quiter and you free up some power as well. Just my 2 cents. Good question about the bypass valve. I'm not sure about air restriction.
Good luck
