All_Motor_KA wrote:Yo dude, 240's DO have an air intake temp sensor. It is located inside the air box itself. When you put a cone filter or change the box in anyway you lose that sensor.
What engine are you talking about? OBD1 KA24DE, OBD1 KA24E or OBD2 KA24DE? I know for a fact that OBD1 KA24DEs do not have an intake air temperature sensor. There was no such sensor in my airbox, nor any wiring for one or even a place for one to go.
Quote »AND FYI insanity, backpressure is a good thing.[/quote]
No. It isn't. Backpressure inhibits scavenging and causes nothing good. What is actually desirable is exhaust stream velocity, since you can attain a negative pressure (read: less than 0 backpressure) in the exhaust pipe due to bernoulli's principle.
The whole "you need backpressure" myth was started because people found out that they could make better gains with a pipe of a smaller diameter as opposed to a larger one, and people drew VERY wrong conclusions based on that piece of information.Quote »Why do you think Ferreri has v10's and sti'll a 1 3/4 inch exhaust?[/quote]What ferrari has a 1 and 3/4 inch single outlet exhaust? Also, "v10" means nothing about the engine displacement. If they have a 1.0L v10 (some types of formula racing use those, or have in the past), then a 1 3/4" pipe is pretty reasonable if the CFM output is low enough.
