help a brotha out...thanks
nolaws4evr wrote:sounds like the same deal I had earlier this week. It was caused by a vaccum leak that I fixed. Try searching for any leaks or vaccum leaks, if you find nothing use a vaccum pressure gauge to check if its steady. Check the MAF sensor plug, my not be attached well. Go over everything and look for obvious problems.
Josh
