91nis240 »
https://forums.nicoclub.com/91nis240-u1852.html
Tue Dec 10, 2002 7:41 pm
i think what he means by "giving off air" is that air sucking sound from the intake when you give your engine a quick revv. But either way hes just sayin his engine is not bringing in air as hard as it should. Ill jus throw out a few suggestions. take you intake off make sure your throttle body it clean, then pull the throttle cable (or have some on hit the gas petal) and make sure the flap in the throttle body is openin and closing as it should. Also i doubt this is it but just check your throttle cable make sure its tight
my 2 cizents!
