Intake pictures
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
John Dixon
Car: 300ZX-TT Z32
Finally started getting the drawings of the IR intake knocked up after having a few months off the car due to loads of personal issues.Dimensions across the block are approximate at the moment, was just wanting to check space really, still need to go and measure up the engine accurately to make sure nothing fouls. Haven't even seen it for months
Obviously there will be air boxes on the end of the runners!
John Dixon
Car: 300ZX-TT Z32
Another:
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
John, those look great!! What program are you using to model those?
Id love for you to email me any pics that you have so i can put them on my NICO gallery (and on VH45DE.com later)
John Dixon
Car: 300ZX-TT Z32
Hi Wes, I think it's autocad. I just sketched them and the guy making the bodies knocked these up. I'll send you some more pics as and when I have them. As I said, had a hellish few months and not got anything done recently all sorted out now though so hopefully get some real progress soon!Engine build is nearly done and will have some more pics of that soon
elwesso
2007 BMW M Coupe
Oh i thought you made the drawings... sorry... Definitely does look like autocad....
CANT WAIT to see the SCREAMER live!!
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Nah that's not autocad, that was done in Solidworks 2006... can tell by the default gradient background and the way the dimensions look.
Autocad's a 2d drawing package, Inventor's the 3d version and looks different.
Nice design! Just curious, is this setup meant to run with a map sensor or what ?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Tuned length calculated for peak torque?
What woudl be the advantage of this over the spider intake?
Nice, but I wonder about hanging the air boxes off the manifolds with out additional support, and they space they will occupy. Plug changes will not be pleasant.
John Dixon
Car: 300ZX-TT Z32
No MAP sensor, will be mapped using throttle angle for load position (NA setup).Yes, tuned length calc'd for about 5000rpm but will have several different trumpet lengths to try out on the dyno.The air boxes won't be hung, they'll be braced off the engine somehow plus they're only very thin aluminium so very little weight anyway.Plug changes won't be that bad, just remove the runners from the bodies on the flange shown on drawing below. Even if they are then I'm not too bothered, if it takes a couple of hours so what?
Intakes will likely wind up similar to this.
I have a similar setup on my KA-T and the airbox weighs maybe 4 lbs. The runners are more than sufficient to support it.
John Dixon
Car: 300ZX-TT Z32
Yes, similar idea but with having a throttle on each cyl then the box sees no real vacuum and can be very lightweight.
Mettler
I'd be inclined to think that 8 throttles would create more cumulative restriction to the airflow than a single one would, consider the increase in volume/surface area directly in the air path.
While you're still in the design stages... it might pay think about custom sliding throttles (or even iris style), so when fully open, there is literally nothing in the air's path.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Mettler wrote:I'd be inclined to think that 8 throttles would create more cumulative restriction to the airflow than a single one would, consider the increase in volume/surface area directly in the air path.
Yeah, for racing when things are WOT a lot more. But sliders have not so very good airflow characteristics at partial deployment lower rpm.
Individual throttle bodies will work great in modualting the airflow.
But no filters? Shame to see all that good work destryed by dust so quickly.
John Dixon
Car: 300ZX-TT Z32
The cams I'm runnning will never idle on a plenum, so ITB's essential. 48mm plates on this engine will be just fine, restriction is minimal as they're spindle less butterflys. I did look at roller barrel bodies but you're looking at ~£2500UK a set!! Also, remember this intake is matched exactly to the ports on each individual engine and all joints are virtually seamless, it'll flow OK!There WILL be filters on it, they'll just be on pipes on the end of the air box, up front beneath the nose cone being fed nice, cold air. Would never, ever run without filters.
Return to “VH45DE / VK45DE / VK56DE Forum”
