intake options rb20 s13
cademfjohnson
Car: 1986 Nissan 720 pickup
KingCab z24
is there an aftermarket intake system for an rb20 swapped s13? will one made for the r32 skyline gts-t work? wanting to replace the unsmooth rubber intake.
example given below
http://cgi.ebay.com/ebaymotors...AX:IT
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
cademfjohnson wrote:is there an aftermarket intake system for an rb20 swapped s13? will one made for the r32 skyline gts-t work? wanting to replace the unsmooth rubber intake.
example given below
Not worth it if u ask me. The Stock turbo isn't all that great and any improvement in HP will come from a upgrade and injectors.
cademfjohnson
KingCab z24
as popular a swap as this is i figured there'd be something on ebay i could nab and slap a good filter on... this is sad.
o well, not a big deal to make something
still be interesting to find out if there's something out there, if anyone knows
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
you can use the sr20 "hard intake tube" that fits inbetween the maf n turbo
cademfjohnson
KingCab z24
thanks a ton!
cademfjohnson
KingCab z24
well damn now i can't find this part anywhere
Sil240
Car: Nissan S13 "The One Cam Wonder"
Just use the stock one, your gonna waste your $$. Unless the biggest Turbo your gonna go to is the rb25.
cademfjohnson
KingCab z24
alright cool. nah in a while its going t3/t4 top mount
Sil240
I believe you can mount that Turbo to the stock Manifold. I would slap a EWG on it and call it a day.Unless your gonna go 6boost.All other Manifolds will need some kinda modifications. Aka money plus they may crack.Your cast Manifold won't and of it does you buy another one for $30
cademfjohnson
KingCab z24
yes but the top mount holds appeal to me in that inner ricer sort of way. shiny and "out there" BAM! haha.
90240sxca18
Car: 1990 nissan 240sx ca18det
Just use the stock one....why dont you like it? Its not like you stare at it for hours while you drive....its efficient for the stock turbo, and holds the maf and intake far enough away from the turbo to keep from heat soaking....if you really want to, just go to auto zone and get some metal piping, cut and weld it to your preferd placement, then just hook it up to your turbo with couplers and clamp your maf to the end, and a filter to the end....which in my eyes would be a waste of money.
cademfjohnson
KingCab z24
its about looking good. and the stock one doesn't. but i decided to just go bigger before i do the small s*** anyway, i was just curious if anyone knew of a replacement aftermarket... apparently not.
