Intake mods for J30
drape123
Car: J30 94, REAL CAI W/POPCHARGER, ECU-Reflash. (the DD) - 95 S14 KA-T Fully built gt35r@28psi when i ge
Has anybody attempted a REAL cold air intake system on a J? if so could you please post pictures...
also if any of you have made a heat shield (or purchased one) please let me know how to do it...
thx
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The factory has a very effective cold air intake, IMO.....
driverdriver
Car: NICO's longtime resident Canuck!!!
elwesso wrote:The factory has a very effective cold air intake, IMO.....
I agree. There aren't any power mods for the J except for the Jim Wolf Technology pop charger. That's about it.
elwesso
2007 BMW M Coupe
JWT makes an ECU as well...
I wonder if you could use a 300ZX ECU?
driverdriver
I believe the 300ZX ECU is configured to run the engine and transmission on a lighter car. The J is heavy. That's what one of the mechanics at the local Nissan Z tuning shop told me.
elwesso
2007 BMW M Coupe
I wonder if it woudl be worth a little money to try it.
DominickJ30
Car: 1993 Infiniti J30t
No you cannot use the 300Z ECU.
drape123
You can't? i've had a 300zx ecu in my car for a few months now, works great
yodawill2000
Car: 94 Infiniti J30
~The plot thickens~
DominickJ30
drape123 wrote:You can't? i've had a 300zx ecu in my car for a few months now, works great
driverdriver wrote:I believe the 300ZX ECU is configured to run the engine and transmission on a lighter car. The J is heavy.
Your J is not running like it should be then.
vishesh
Car: '95 Infiniti J30
oh damn. somebody is about to throw it down.
yodawill2000
~~Buys some PopCorn~~
hehe
dr seventies
While not a "cold air" solution, there is another choice for your intake. Stillen http://stillen.com/Sportscars_...age=1 is a well reputed Nissan tuner that also offers an ECU.
driverdriver
Is that a CAI or WAI? All it states is that its an intake.
NismoChi
Car: 94 J30
It looks to me with just a cone filter, adapter and a "velocity stack", the filter would still be in the engine bay sucking all the hot air.
yodawill2000
The venturi effect could be done with a little fabrication .
Ive mad a few Furnace Burners for My backyard foundry that uses that theory .Most effective . Only prob is it would need to be at the tail end of the airflow path just before mixing with fuel .The airflow amount is the same , just the velocity increases.
driverdriver
I was talkiing to one of the guys who is one of the principles at the local Nissan Z tuning shop.
In order to get a 300ZX ECU to work in a J30, you need the 300ZXTT JDM engineclip and a 300zx turbo. Otherwise you will (or already have) damage(d) both your engine and transmission. The ECU needs both components to work properly otherwise over time the engine simply self destructs. Although the 300zx and J30 engine are the same, the components where machined to different tolerances.
drape123
Well im not an expert, but I took my ECU out and downloaded the data on the ECU and interestingly enough, it almost matched a 93 NA Z32 100%only minor differences like rev limit and speed limiter, thats it. So i made some updates like change timing and burned a new EPROM... Went to my J and cranked it over a few times and she came to life!!!! with a CAI and pop charger filter im running at about 239hp right now. (car pulls hard all the way to redline)cant wait to install underdrive pulley.
also about transmission, there is a seperate computer that controls it, i never touched it.
DurtyJ30
Car: 1995 Infinity J30T
drape you started this post asking if any1 could show you how to do a cold air intake. and you ended the post stating that you have a cold air intake. now im askign you the same question that you started with the post. how did you do it? custom or where did you buy it ?
drape123
kinda ghetto, i removed the old air box, cut a hole in the metal where the air box was and dropped a 3" air pipe into that hole under the engine bay. also i wrapped the whole pipe and surrounding area with reflective insulation that reflects 97% of the heat thrown on it. it works awesome. i'll post pic's soon.
robmcole
Car: 93 J30
I remember a long time ago people on the forum were saying the 300zx is a 8bit ECU, and the J30 is a 16bit ECU, so it would not work correctly. Take it for what its worth. If you want a faster car, sell the J, or get a second car to do that. The J is a beatiful and comfortable machine, but not a fast one. I am currently saving up for a second car cause I miss my manual, but could never sell my J, too reliable and comfy!
not bashing, just something I had to realize myself
DurtyJ30
i fully agree with you. thats why im buying a sports car for the summer.
elwesso
2007 BMW M Coupe
robmcole wrote:I remember a long time ago people on the forum were saying the 300zx is a 8bit ECU, and the J30 is a 16bit ECU, so it would not work correctly. Take it for what its worth. If you want a faster car, sell the J, or get a second car to do that. The J is a beatiful and comfortable machine, but not a fast one. I am currently saving up for a second car cause I miss my manual, but could never sell my J, too reliable and comfy!
the 90-93 ECUs had 8bit, and the later ones had 94+ had 16 bit... Same way in the Q45... im running an 8bit ECU on my 94 which came with a 16 and it works fine.
diamond
Car: Wife's Daily driver is J30 , 58 Cheby Sport Sedan Lowrider is my style .
be cool to make a lexan box around a pop charger with oem feed and back light it.oh ya baby.be pretty easy.look trippy too.lol
