progman wrote:Male on Male kissing??
Are not not a male? No offense if you're not, it's just that your Screen Name is "Progman" and your profile say's your name is Benjamin.
progman wrote:My friend was revving the motor and we could hear what sounded like air leaking some where (near the turbo). But we could only hear it while the car was slowly revving or just after letting off the throttle. (This is not the waste gate noise)
This is my boost gauge when you let off the gas:
0 psi drops to 23 psi
we hear the leaking noise
then I have 17 psi
I think something is wrong.
Do you mean 0psi drops to 23 in of Hg or cm of Hg?
Regardless, yes, you will have more vaccuum when the motor is reved up and then the throttle is closed. If you're turning the motor at 3K RPM and close the throttle it takes a little bit for the RPMS to drop to idle and during the time the vaccum is going to be high.
The car should be rich at idle. This is normal, although I think 10:1 is a bit rich when the motor is at NOT. Mine is at about 11:1 at idle at NOT. It may get as rich as 10.5:1 when it's cold and I first start it.
What exactly is the problem that you're experienceing, just being rich at idle, or does the car run poorly?
A vac leak on a MAF system will make the car run lean under vaccum and rich under boost....
