intake manifold
badassmini
Car: 93 hardbody
I ve seen a few hb with a 240 intake manifold and was wondering if a ca18 intake manifold would fit on a ka24 as well. granted the block on a hb and 240 are the same, but a friend has one layin around and is giving it to me so i just wanna know that it would fit for sure before i start to take everything apart.
RT22
Car: 1991 nissan hardbody
what is the reasoning it putting it on? is there some performance gain?
moneymike
Car: 1991 nissan d21 hardbody
im using the intake manni off a 240 on my hb
seang
Car: Ford Fiesta ST
I doubt the flange is the same. I would be suprised, though, if it was.
I guess you might be able to weld the CA manifold to the KA flange if they lined up right, that could possibly work.
They made alot of single cam 240's, around 126,000 of them I think; so there might be some manifolds still out there. Maybe you could just trade the CA manifold for one of those. Good luck!
RT22 wrote:what is the reasoning it putting it on? is there some performance gain?
Yes, there is. It's not the end of the world, but it is more "hot" that the truck manifold. You would probably get 4~6 more hp with a 240sx manifold swap.
badassmini
Car: 93 hardbody
i didnt know there was that much of a difference. i just wanna swap it out to get rid of that big a** throttle and air filter. it make the engine look crowded and on top of that a 240 manifold make it look so clean!!!
seang
Car: Ford Fiesta ST
SOHC 240 intake manifolds do look good, I will say that. And when compared to the truck version it's easier to clamp a silicone turbo or cold air intake (CAI) connector to, too.
moneymike wrote:im using the intake manni off a 240 on my hb
Did the 240 MAF sensor plug right into the truck harness or did you use the 240 ECU as well? I have been wondering about this, you know, since the truck has the MAF integrated into the throttle body. Even if you did the manifold swap, are the stock MAF wires even long enough to reach where they need to go?
Another thing about the truck MAF is that only a fraction of the incoming air passes over it, contrary to a "normal" MAF. Does a "normal" style MAF put out the same signals?
