Xoltol »
https://forums.nicoclub.com/xoltol-u79640.html
Fri Dec 21, 2007 2:39 pm
Ok, I went to replace my timing belt because we heard what we thought was a snap and the car can't start... And we came to find that our Idle Pully just completely severed itself from the engine... Fine, we order an idle pully, remove fan and timing belt cover, Had to drill a hole in the Snapped part of the screw to try to tap it... got a small hole managed to tap it but the screw did NOT move at all, so we figured it melted in ( Seeing as how a mechanic said the Pully snapped from heat stress ) So we attempt to drill out the hole, but someone ( i won't say who ) decides to drill at an angle... so now i have an angled hole where the screw should be... the screw isn't completely out, and i need to re-thread a COMPLETELY different hole... Or... someone threw this out for me... get a new Manifold... now my main question is..
Is the thing the idle pully attacted to the Intake Manifold? if so how much would a new or used one run me, could i order it from like discount or something? or if it's not the intake manifold... what is it and where can i find myself a new one... because the one in the J30 atm is currently Drilled in on the wrong angle.
Please help D:
