Because it's engine efficiency.Edub1 wrote:How much benefit would such a manifold be over stock?
Say a guy has a T3/T4, is he going from 400HP to 500HP at the same boost level?
What is the actual HP gain and how is it so much better than another few lbs? By the way, manifolds are specifically tuned to the motor based on tubal resonance and many other factors so you would probably have to do a lot of monkying before you get it right.
Like I said, if you want sick power that is a different matter. How much does a good aftermarket one cost?
With an intake manifold properly designed to make power you will see less exhaust backpressure, lower boost temps, greater turbo life, lower oil temps, lower coolant temps, and you can more accurately take advantage of a turbochargers mapping (maps are widest at lower pressures).
It's not about the power, it's about the efficiency and doing it right. You could make 600whp on a stock manifold thats been hogged out, but the powerband will not be ideal, and you will be pushing the turbocharger hard.
