intake manifold spacer
flames5351
Car: 95 nissan 240sx SE
Ok so I bought an intake manifold spacer from enjuku... I needed a gasket so i figured why not. When I installed it my throttle now won't close all the way unless i lift up on the pedal. Is there any way I can adjust the cable? or what do you suggest I do to fix this???
thanks all and yes I did search
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Are you using a non stock throttlebody and if so which one? Enjuku actually offers a tb spacer so no backyard mech action needed.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
bend the mettel peddal stop 1/2 inch thats what i did!
ser2102
Car: 91 dead. 90 getting did
at the end of the throttle cable, there are two nuts that are used to adjust the length of the cable. there should be a little plastic tab that holds it all in place. take that off, undo the two nuts, 14mm, reposition the throttle cable, re-tighten nuts, put back in the plastic tab. enjoy the normal throttle position.
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
Have you noticed any difference with the spacer?
supreamS14
installed mine when I did the swap while the motor was out
