No, no mater which car you choose the years don't change .Infantry1327 wrote:It will let you add a 2008 altima kit to your cart on there. So maybe they have allready have it.
I want this plus y-pipe plus shortshifter lol
lol! oops!windex wrote:http://forums.altimas.org/zero...acers
I say someone still contact them for the healthy low and mid range boost!!windex wrote:I was looking into information about the SAFC Neo and somehow worked my way to Intake Spacers. Found a company that makes them for 2002-2006 altimas so I fired off an email about them for the coupe. This is what I received:
We do not currently have any plans to make Intake Spacers for the new modelAltimas. We would definitely be interested in conducting some testing tosee if you would benefit from intake spacers.
Also, since your intake manifold is made of a plastic composite, it is noteffected by heat like the other Nissan engines are. So, heat soak isn't abig issue for you. You will not need a Thermal Intake Spacer to helpinsulate. But, we are currently designing an aluminum intake spacer for theVQ40DE Frontier engine. What this will do is shift the torque band lowerand provide a healthy low end and midrange power gain! Proper testing willneed to be conducted on the Altima to determine the optimal spacer design inorder not to hurt top end power substantially.
Please let me know if you have any more questions.
Thanks,
Aaron KimballNWP Engineering, Inc.http://www.NWPEngineering.com252-747-7672
Not even sure why I posted this but I guess its an oppurtunity for someone to get something free.
omg...who cares? it shifts the power to low and mids.LinkNuc wrote:I don't understand why he'd bother to make a kit that if anything will rob high end hp? Why are you so excited to make less horsepower?
This is more than a TB spacer, it is a kit that includes spacers for the manifolds/heads aswell. The material is a glass based phenolic, not a paper based, not only did the IM spacers raise the IM's volume, glass based products are very resistant to raised temps. So by not transferring heat to others components it dropped the ambient temp of the air entering the engine. Colder air = more power.LinkNuc wrote:Yeah, I'm still calling shenaningans on this snake oil. But if ya got the money to waste, then don't buy plastic voodoo, you should waste it on strippers so they can go to "computer classes"...QC has some real nice "entertainment"
