HotSauceVersion wrote:Now what would be the smartest way to take the fuel rail off?
I'm not generally one for doing things the smart way, but I can give you a fast way to do it.
you'll want to remove the breather hoses from the valve covers to give you more room, pull the intake manifold wiring harness out of the way (make sure to label the plugs so you know which injector plug goes to which injector and stuff), and you might consider removing the valves on the inside of the intake manifold. Then you will need to remove the lines from the FPR (pull fuel pump fuse and run until it dies so you don't get gasoline everywhere). After that undo the three or four 10mm bolts holding the little black braces on the inside of the intake manifold, I think they may hold on the fuel rail (or maybe they just brace the upper and lower manifolds together?) but I don't know for sure and I can't go look at my car because I am on campus. Then it should be a pretty simple job of unbolting the fuel rail and yanking it out. The injectors should come out with the rail, or they might stay in the intake manifold, either way they are now exposed and you can do your dirty work.
Boo bam! Shouldn't take you more than an hour to do it all, so long as you have the o-rings already.
