Intake manifold removal
2fast4u1104
Car: 1989 240-sx
I just got my 240 three days ago and the only thing it needs is an intake manifold gasket and i took the top half off and all the top bolts out of the bottom half and the two on the bottom but it still wont come off any help would be great.
navysnail
the gasket kind of holds it together, you may need to use a plastic paint scraper (so you won't scratch the soft aluminum) and break the seal between the two. you can also use metal if you are careful, but you do run the risk of damaging the manifold.
JeromeS13
Car: 2008 Subaru Impreza STI
My favorite words almost always apply: Factory Service Manual
vancouverbc
Car: 1991 240sx
fsm in my signature
rotorimp
Car: 02 Xterra, 60 IH Metro
IF your 100% sure all bolts and nuts are off--give it a little tap with a rubber mallet.
