VanNelson »
https://forums.nicoclub.com/vannelson-u35005.html
Thu Jan 26, 2006 3:16 pm
I've found that unbolting the intake from the collector, then pulling the cylinder head off, taking the intake manifold off was no problem. The EGR valve, btw, connects to the collector, therefore it doesn't need to be removed if you're taking the head off(just unbolt the collector from the intake [5 bolts]). For the lower 'plenum', there are three mounting bolts on the underside, five on the top (connecting to the intake), EGR, various small hoses.
