Intake Manifold HELP!
Pento240sx
Car: 1995 Nissan 240SX SE, 1981 Datsun 210 Deluxe, 1981 Datsun 810 Maxima Deluxe and 1999 Infiniti Q45t.
I been trying for the past hour to take of the top part of the manifold. I took all the bolts and nuts out, but it seems to be stuck with the silicone. What are ways that could help me, on removing it? Thanks.
Razi
Car: Moo
Is the top half stuck to the bottom half of the manifold? Or is the top half stuck to the head?
Anyways, try to wedge a breaker bar in there somewhere and push or pull.
That's what I did.
Also make sure to check that all the bolts are out, I forget sometimes.
Pento240sx
I got it unstuck. Well I was trying to take of the top half, but it seems I need to take the bottom part too.
Pento240sx
Ok I figured a way out and I will try it tomorrow. It's called the double nut method (No h0m0), so I could remove the 2 studs from the block. I hope this works.
