deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Feb 02, 2006 4:29 pm
The port shape will depend on where you want to mount your injectors, or should I say if you plan to run staged injection (twm's having their own injector mounting). You will definately benefit in the fuel efficiency department by having a set of primary injectors mounted in or near the factory location. Using staged injection you can setup so that only your primaries are used for low load/cruise/idle condition.
In that situation, I would suggest using the oem manifold as base. Retaining the original flange, injector mounting, and a few inches of the runner. The twm dcoe mounting pattern will line up well with the factory port spacing, and with ample center spacing for the linkage. Personally, I would mount the throttle bodies upside down, with proper angle, so that the secondary injectors are shooting in from the bottom more parallel with the port. You can potentially angle the throttles so that the injector shoots direct to center, much easier than if they were on top.
If you want to use only the twm injector location having the single set of primary injectors 4-6inches away from the port flange, you can go to a semi-oval port design. This will be much easier when manufacturing a manifold and fitting the runners. It is best not to complete redesign some one-off port shape for your head, the small cavity that was once tip of the tear drop will cause little negative side effect.
