intake manifold differences
sunnys14
Car: S14
is an intake manifold off a 95 KA obd1 the same as an intake manifold off a 97 obd2? does any know?
Craving4Boost
Car: 91 240sx fastback
just to let you guys know hes not making a mistake on the obd1 part....he has the exception s14 with a obd1 ecu.
ill just say what we talked about before...im guessin the 97 s14 has a diff TPS than the s13 like most s14.
Structure240sx
OBDI tps is different than OBDII, also there are extra emissions/vaccum crap on the OBDII manifold
i think the water temp sensors might be the same
sunnys14
Car: S14
so that means i would have to swap my TPS from my 95ka to the 97? what do i do about the emissions bull****?
Structure240sx
if your 95 is OBDI like mine then yes. emissions if you want you can toss and cap off any open vaccum lines
all you need as far as vaccum is the fuel pressure regulator and brake booster
sunnys14
Car: S14
structure, youre such a cool guy
sunnys14
Car: S14
without all those vaccum lines, can i still pass emissions?
steve s14
as long as the vaccum lines aren't just hanging there and they are removed and the fittings capped, it should pass.on an emissions test, they will only be testing for the emissions equipment that should be there for the year of the car, not the intake manifold on the engine unless the whole engines been swapped.
Structure240sx
cali is alot different with inspections than NJ is
steve s14
yeah, i figure what will pass in socal will pass anywhere, since they are so strict when it comes to emissions here.
