idahotuner wrote:and i just want to find a way to make the engine bay look clean. cover all the wires.
Also as far as keep ing heat out. it might actually do it. liek a heat sheild for the brake and clutch fuild. crowded huh? i think i will do a photoshop version first and show you what exactly i mean.
If you want to make your engine bay look clean and cover the wires, I think a better idea is to relocate your wires below the manifold. Redo your wiring harness a little. Subtle is key.
And you say like a heat shield for your brake master cylinder....the purpose is to keep the brake master from absorbing the heat from your exhaust manifold. But like I said there really isnt any heat source near your intake manifold. So putting a shield over it is keeping heat in. And that means hot air going into your engine which will decrease performance. Maybe not much but still, cooler air into the engine is ideal.
And if you have a heat shield on your intake manifold, exhaust manifold, etc...I think it will look like too much and maybe tacky. I could be wrong...try it out and let us see it. If you look at pictures of some people's engine bays....the best looking ones are the ones with the least stuff in them.
