intake manifold bolts
m1dt0wn3
hey guys quick question...on the intake manifold, there are 2 long bolts that go somewhere. I forgot to mark where they go and I need to know before I can do anything...any help would be appreciated. also can anyone tell me where a really good diagram of the intake manifold is. thanks
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
They go from the intake to the head, right under the set of 3 hard vacuum lines that run parallel to the plenum.
And what do you need to know of the intake manifold? Vacuum lines? I have the FSM page scanned into a .jpeg but i cant seem to upload .jpegs. Let me know if u need it, i can email it you.
m1dt0wn3
yeah dude...where is the plenum cuz people have been referencing to the plenum but I don't know what it is or what it looks like. If you can e-mail that to me it would be great. my email address is [email protected]
JNM240
I just sent the vacuum diagram.
The plenum is the top half of the intake manifold, the rectangular peice the throttle body attaches too that has ECCS written across it. The vacuum diagram calls it the Intake Manifold Collector. It bolts to the intake manifold, but, depending on what all you have removed already, you may not need to remove it to get to those two long bolts. Hope this helps.
m1dt0wn3
yeah dude thanks alot, I just got everything in...and now I gotta do timing then I'm done
