brunswick240 »
https://forums.nicoclub.com/brunswick240-u25911.html
Mon Sep 04, 2006 3:46 am
Alright heres the updated, all the coolant lines are hooked up and i later found out that i had a coolant line hooked up to the pcv thing on the bottom of the intake mani (4 rubber hoses going to a common hardline with a nipple coming off in the center which hooks up to the breather separater). But heres the new problem, engine wont start....Ive got spark, and gas, but it just sits there and cranks away. Now ive got this wire that i couldnt figure out where it goes to but its pretty heafty but i just disreguarded it here is a pic of it....now the other problem is that im thinkin that it might not be timed right. I set cyl 1 at TDC and had everything all lined up from the crank sprocket, to the cam sprockets, to the marks on the crank pulley. Ill get a picture of that wire but if you guys have any suggestions that would be great. FYI: I took my evap canister off, and all those hardlines on the intake manifold for emissions, i blocked the egr on my exhaust mani, took those two round things off, and all that stuff. I just put a screw and rtv'ed around the screws for the holes that were left on my intake mani. So if there are any common mistakes when taking all that stuff off please suggest that because this is my first time taking the emissions stuff off. Thanks for the help once again.
P.S. The gasket problem was that the night i was putting my intake manifold on it was around 1 in the morning and i had been workin on my car all night - i forgot to scrape the old gasket off haha no excuses just a stupid *** mistake . Fixed that and no longer and leaks so im somewhat happy haha.
