lucky03602 »
https://forums.nicoclub.com/lucky03602-u20182.html
Sun Oct 04, 2009 12:12 pm
finnaly an update!!
well i finally got the fuel rail delivered last week or so, and since i lost my spacers and needed another bolt for the rail i went out and bought them (bolts are m8 1.25 25mm, washers are m8 5/16)
put the new rail in, bolted everything up (used 3 washers between rail and upper intake) and started the car up
started right up with no issue, idle'd at 1700rpm for a couple mins then i hit the gas a little bit, and it went down to 800rpm and idled very very smoothly and strong.
so now i got the engine back to running condition and even better its running much much better i got to replace my high pressure power steering line, rear pads, turn my rotors and replace one caliper.
also what i did to my engine in all was
removed both timing chain guides and sprayed the tensenors, cleaned the 2 sensors inbetween the upper and lower intake mani's, removed all emissions, removed 2ndary butterflies (left the rod in, btw there is no more whistle!)
i only have one vac line coming off the lower intake mani straight to the fpr. i still have all the other hoses and t's for when i do turbo it though!!
