mickeyd420 wrote:i had a "buddy who is a mechanic " TRY to install the intake, after he fluxed it up i took it to my mechanic.. The oil leaks are completey diff. I replaced the maf and that didnt do anything. My mechanic said he has tryed everything, something as simple as a vacum line wouldnt be the problem
I dont mean for this to come across as rude, but Im probably just saying what everyone here is thinking:
With all due respect, your "buddy mechanic" is an idiot if he effed up a freakin intake install. And hes even more of an idiot if he just replaced you good working MAF for no reason. And this other mechanic guy you took it to after that did no better. They BOTH should have asked you if there was a reason you were electing to have the MAF replaced. If it isn't broke, dont fix it! Now intake installs are about the easiest thing you can do to freakin car. If you mess that up, you shouldn't be under the hood, period. They even come with instructions.You never actually bothered to check for vacuum leaks did you? Please don't come on here and start a thread asking for help and then ignoring the help that is offered. The guys on here know what they are talking about for the most part. A vacuum leak can cause all kinds of problems and coupled with your incorrectly installed, who knows if its working MAF, you're going to have all kinds of issues. The oil leak is indeed a separate issue. Go to another mechanic or to a reputable national chain and get ready to bend over. You might as well fork over the cash to have this done right since you obviously aren't confident enough to handle an intake install on your own. And you might want to read this again:
1) Stop going to that mechanic.
2) Install the STOCK system. Intake systems DO NOT do this to cars - it's the installer who is f'ing it up.
3) Use the original MAF for the car - undo the splicing - that is just straight up stupidity to run anything other than the stock MAF for a car w/ just an intake & stock ecu.
Oil leak is something completely separate, trace where it is coming from if you can, but the intake issue should be an easy fix if you still have all the original equipment & maf.
Once you've returned everything to stock, then put everything back in one by one.
There are really only 2 things that could have gone wrong when he installed your intake
- the maf splicing f'ed up the maf or you car (hence return this section to stock)- he didn't connect a vacuum line (hence putting the stock tubing on for now - that takes about 10 minutes).
That is all, good luck.
