INTAKE INSTALL ISSUES!!!!!! HELP PLZ
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
versatuner92
Car: 2012 versa s hatchback 1.8l
Ok so I installed a spectre kit for my tubing on my 12 versa s hatch well I unlpugged everything like the you tube video and I had to cut my own mas air flow sensor well installed tubing and cone filrter and turned on my car and bam Boggs down after two second and I took everything back off then re installed facotry stuff and it idled fine no issues but now have a check engine light? Idk why the car Boggs down with the filter on and even with the after market tubing and no filter it stil Boggs down but works fine with facotry stuff it shouldn't be mass airflow could it? Do I need a different filter and tubing? I can't afford the 175$ and up filters on line help would be awesome
DizzyKitty
Car: 2000 Maxima SE- in pieces in yard...
2014 Versa Note - Wife's vroom vroom machine
Post a link to the video you followed.
Did you do every single thing that was done in the video?
what do you mean you "cut" your mass air flow sensor?
Return to “Versa Technical Discussions”
