blacksrjdm »
https://forums.nicoclub.com/blacksrjdm-u52167.html
Wed Dec 09, 2009 5:34 am
Wow, is this really where we are, Instructions to install a short ram intake?
there should be;a coupling to attach to the throttle body,A aluminum pipe to attach to that coupling, some sort of adapter plate for the MAF,and then your filter.
When you say "basically new" I suppose you mean that you got it used or, someone ripped you off for $25 and gave you a Civic intake, (that wont work).
Search "short ram""Intake""Injen"
This is a complete no brainer. You remove the stock intake tube and box, then install the intake in exactly the same place you removed the stock one.
