Intake Hole?
xns
Car: Computers and cars
There are three holes on the intake tube right? What is the third and biggest one, located on the underside towards the throttle body end used for? What tube connects to it? Does any tube connect to it? If I dont know what connects to it can I cover it up?
ziggy682
Car: 1991 240SX Turbo
That's just a resonator. Yeah, you can cover it up. I believe the resonator bolts to the fan shroud. I don't really remember, because I haven't had the resonator or the factory fan shroud in a long time.
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
ziggy682 wrote:That's just a resonator. Yeah, you can cover it up. I believe the resonator bolts to the fan shroud. I don't really remember, because I haven't had the resonator or the factory fan shroud in a long time.
the resonator is behind the bumper...
allthrottlenobottle
Car: 91 s13
resonator under drivers side bumper and one bolted to the fan shroud 2 in total
xns
ok so lemme get this straight, this giant gapping hole is a resonater... somehow that just does sound right...
allthrottlenobottle
Car: 91 s13
resonater on fan shroud is narrow and long the resonater under the fender is rectangular about 12x6x6"
xns
wth, im so confused...
allthrottlenobottle
Car: 91 s13
explain.....
xns
nvm, I found that the bottom black part of a film canister works just great in plugging up the hole, when I did I noticed a significant amount of hp gain :D and the engine ran smoother
allthrottlenobottle
Car: 91 s13
good job!
ziggy682
xns wrote:nvm, I found that the bottom black part of a film canister works just great in plugging up the hole, when I did I noticed a significant amount of hp gain :D and the engine ran smoother
The big gaping hole isn't a resonator...DUH!!!
The thing that's suppossed to be attatched to the big gaping hole is a resonator...DING!!!
I thought that was pretty self-explanitory, but I guess not.
Want to know why your engine has more power and is running smoother now?
You were letting in lots of air that was unmetered (and unfiltered) and causing the engine to run very, very lean. It's a good thing you didn't have any detonation caused by the lean condition, cause you would need more than a film canister to fix your blown engine.
xns
I knew that :duh
