Darius »
https://forums.nicoclub.com/darius-u5470.html
Fri Jun 27, 2008 4:24 am
Efficiency and part matching is very important in a NA application, but with a FI turbo application, the turbo does all the work and fuel/timing tuning make all the difference. Yes, some parts may make the turbo spool faster, but we're talking small rpm increments.
If you want 400hp and a fast spooling turbo, you should run an internally gated 3071R with ~500-550cc injectors at about 20 lbs of boost with a standalone to dial it in. A tubular manifold will help spool it faster, but like I said, only a few hundred rpms faster than the stock log manifold. Stock unit is solid from the factory. Try that setup on for size and if it doesn't meet your expectations, upgrade the intake manifold and valve train.
