Here's what I'm working with (please excuse the wires everywhere. I'm in the middle of a wire tuck):
This is an old image. The suction pipe and MAF did a 180 and go down under the right frame rail and into the wheel well behind the splash guard. Also, you can see the immediate bend the hot pipe does right out of the turbo.
Here's a shot from the top. You can see where the alternator and compressor sit and you can kind of see where to turbo inlet is.
This is the same shot, but from the bottom.
Here's the hole where the MAF and air filter went. The compressor is in the way now.
Just another view of the turbo.
I've got all this space now where I was thinking of putting the suction pipe if I can turn the turbo on the manifold and face the inlet towards this area. So far this seems to be my only solution. Only problem is I'll need braided stainless feed lines and a new oil drain. But that's probably not too big of a deal I would think.
So what are y'alls thoughts on this? I'm almost tepted to just go again without A/C or P/S. I've never had good working A/C in a car before so I've never used it. And the car is actually pretty easy to drive without P/S as well. But I'd really like to know I can run both just for future reference and for bragging rights.
