Calvin »
https://forums.nicoclub.com/calvin-u5675.html
Wed Jul 16, 2003 6:30 pm
There are several idle air valves on the car. The main one is the AAC valve, and it sounds like yours isn't working. Maybe it needs cleaning.
A second idle air valve, called the "Air Regulator", provides an extra air bypass when the car is cold. Once the car warms up, the bypass closes, and your idle depends solely on your broken/dirty AAC valve.
Disconnecting the AIV hose has nothing to do with the idle. I believe gibbo80 was referring instead to the other hose -- connected to the intake duct on the passenger side of the car. That hose is for idle air, and if you disconnect it, the MAF gets confused and stalls the car. I assume you still have this hose connected because your car still idles when its cold, at least.
I've never heard of the ambient air temp sensor causing a car to die. I don't think your problem has anything to do with the fact that you moved it.
