removing them won't do anything useful, if yours are so gunked up just clean em.
you know why they get gunked ? the previous owner(s) didn't mash on the gas enough!
since there is no fuel injected there in the secondaries, all that buildup is blowby/etc being pulled in through the pcv and if you never drive so as to open up the valves, they'll just collect gunk.
so, let this be a lesson to all - your CA wants some stompin'!
Float did a dyno test not far back showing that having them closed does make dyno'able differences down low.. on his setup, he found the open vs close crossover was at 3750 so he changed his SDS from 4k (stock switchover point) to 3750. But he has quite a few mods..
When you freed them up, did you totally clean them out? If you cleaned them up and they gunkd again, you probably have SERIOUS blowby or something else is really wrong.
