boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Tue May 16, 2006 8:03 am
There have been countless posts about this subject and everyone is entitled to their opinions and experiences and I'll definitely share my experiences on the matter. Back in 1997 when I was running a CA16DE in my sentra, I didn't have the vacuum hoses hooked-up correctly , so power valve did not operate when it was supposed to resulting in good performance, but not the best (very lazy below 4000rpm). The CA16DE bored me, so later on that year, I moved-up to the CA18DE leaving the vacuum hoses the exact same way I had them with the CA16DE set-up resulting in even better performance, but still lazy below 4000rpm.
I finally got the vacuum scheme perfected and with the power valve connected properly, the car/engine was more responsive coming into it's peak torque which is @ 4800rpm. My point on this subject is, on a N/A engine this system is essentially useful for mild to wild acceleration below a given RPM. Given the fact that the CA is relatively small compared to most performance engines being built for today's enthusiast cars (ie Sti,Evo,SRT-4, even the mazda speed), you still can't compare it to any other engine besides itself. I didn't mention the hondas because they are not turbo'd from factory and they use a totally different approach that makes a honda a premiere 4 cylinder builder in the car industry.
Bigger bore, longer stroke, small cylinder head ports, are some of the things that gives 4 cylinder engines good torque down low. A 4AGE or CA DOHC series engine rely heavily upon their butterfly valve system to put back some the low-end grunt that is missing due to their relatively small bore and stroke. On atmospherically driven engines, this system is ideal and have been proven to assist in producing low rpm torque not present in small displacement engines.
But now, on force inducted or turbocharged engines, the butterfly valve system's presence, especially becomes questionable in smaller displacement engines. Case-in-point "Toyota" and their amazing 1.6l 4AGZE (supercharged) power-puppy. Guess what guys, unlike it's N/A 4AGE brethren, it has good grunt from 1200rpm on and amazingly "No TVIS". Now why did they do that when the TVIS was a big hit with the N/A engines? Hmmm, we'll have to ask the engineers themselves, but my hypothesis is the fact that because they were using a blower that gave near instant power in the lower rpms, and since the fact that the engine is designed to rev pretty high and produce power in the upper rpms as well, why waste the money incorporating this system along side a blower.
My CA18DET engine have all revved pretty good and produced wonderful power on the stock engines, minus the activation of the butterfly valve system. I honestly think they are worthless on the CA unless you plan on driving around off boost. I agree that for a track-based platform, they should be X-filed. But once again, beauty is in the eyes of the beholder and one should do what they want to do to make their machine function the way they want it to. With the proper cams or even the stock cams, I can personally and honestly say that the butterfly valves can be removed or left open. They cause a carbon and sludge build-up that is totally unacceptable for me and most people don't talk about that down-fall. At or around 4000rpm, my car is seeing full bost and is producing better than 300whp with a good size, but properly spec'd turbocharger and is producing over 277lb/ft of torque which is more than enough for a street car. Just my snott on the subject !
Dee
Without butterfly valves functioning, 20psi on a T3/T04E with a .48 rear housing and .60 front housing and an internally stock CA18DET as well as conservative tuning.
Without butterfly valves connected, 14psi on a T3/T04E with a .48 rear housing and .60 front housing, an semi-stock CA18DET (HKS 264 cams with a 8.5mm lift) mild programming.
