biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Wed May 04, 2005 7:57 am
you need the solenoid hooked up, plus a vacuum tank, and two particular vacuum check/delay valves.
It does make a difference. If you don't want to do it the right way then just T it into the FPR so at least it'll do something vs nothing. Having them stuck open (unconnected) you loose a ton of bottom end response.
I need to hit hte junkyard one more time but once I do I'll have all those parts that are needed and I'll sell them as packages (just mount it yourself, and run vacuum tubing) for probably in the 15-20$ shipped range.
The old FAQ thread had a huge post from me explaining how it worked, altho I need to redo it to make more sense and also I've found one or two inaccuracies since..
