I went with R2C intake and love it! The build quality is great and the install was a breeze. The engine sounds as it should now
For the exhaust, I looked into doing Tanabe mufflers...but decided against messing with it. The OEM exhaust note sounds good.
Also, I did the NAV bypass and added an aftermarket subwoofer. MUCH better overall sound now! The NAV bypass allows you to change settings while the car is moving. It was a pain to not search music on the HD or make changes to a destination while moving...Search the forums for the specifics. I did a write-up on the bypass and lots of helpful info on the sub.
Here are the links:
http://www.advancespeedshop.com/tanabe- ... -7521.html
http://www.importpartspro.com/r2cpepopekit.html
