Edub1 wrote:I'm glad to hear the EC3 is working for you. Mine actually runs quite well on the EC1 but I do like tha additional features.
I find little reason to experiment with the air temp sensor. What you are experimenting with is likely the timing map for the coolant sensor or some other timing correction map that is erroneously labeled, or the sensor might involve both timing and fuel..
Dude iam not an idiot i think i know which scale and sensor i test. Indeed I spend sometime playing with all the scales, using wideband and timing light along with consult. And scales are properly labeled in romedit. I gave you a few basic tests so you can see for yourself ….But you find little reason to experiment with the air temp sensor..... yet telling people how it operates somehow.(we can all use google)
=AIT should never be pre-turbo on FA motor, look at what you doing. You making ait tell ur ecu that ambient temp of air entering cylinders is +10degC(whatever it is outside that MINUTE). By the time air travels past hot turbocharger and gets compressed on top on that, temp's INCREASE dramatically. Now the air actually entering your cylinders is way hotter vs what ait told ecu. If ait is past turbo.. it tells ecu temps of air actully entering the cylinder than ecu pulls 1-xdeg of timing per scale and overall cylinder pressure lowers, causing combustion temp's to lower and avoid potential damages due to Heat Soak.
So feel free to stick it pre-turbo and while doing 100km/h it will tell ecu intake temps are 0-2deg C, meanwhile you pushing 20 psi+ and actual temps will be 40degC+ . Your ecu will not pull any timing and cylinder pressure will go to the roof, cause extreme combustion temps and damages.
Our MAF counts air molecules going into the motor. You can compress ,heat , cool the air but the number of air molecules going into the engine will remain exactly the same as counted by the MAF pre turbo. ECU needs to know how many air molecules there are not their temp's, to add the correct number of fuel molecules and resault in a specific postcombastion a/f ratio. Changing timing will affect final a/f reading due to length of combustion but not due to some fuel correction based on ait. And that’s all there is to it. Remamber i am talking ka24e here same theory should aplly to DE exept ir also usses feedback from knock sensor and sets correction in place.
Modified by 180sx at 12:00 AM 3/17/2007
