Blood Riot »
https://forums.nicoclub.com/blood-riot-u78730.html
Mon Nov 12, 2007 3:10 pm
in that case you most definitely shorted out a fuse man. I know you will probably doubt what I'm saying, but trust me, it happened to my cousin when I told him it was critical to remove the battery terminal and then work. He found out the hard way, anyway back to topic. Check your fuses man and also your relays, how do you check a relay? I have no clue but I think you can check them with a 9v battery and some wire, its good if you hear it click, no click means no good. Try it , best of luck to you. or just google for instructions on how to test a relay.
