Instrument panel is dark
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
smudge801
Car: 2008 infiniti G35x Sedan
I was redoing wiring to an aftermarket SONY stereo and had the console kit out. Not sure what the connection is, but afterward I had no lights in the instrument cluster. Gauges and warning lights all work, but the cluster is dark. What do you think I did to cause that?
telcoman
smudge801 wrote:
Sat Dec 01, 2018 1:03 pm
Blown fuse?
Missing ground?
Broken wire?
Harness connector?
Dimmer control?
Clusterfvck?
Telcoman
wrightdog26
Car: 2004 Infiniti G35 sedan
Try the rheostat(sp) switch. The one that dims and brightens the dash.
josephcl
Car: 2011 Infiniti G37 Convertible
wrightdog26 wrote:
Sun Nov 20, 2022 9:26 am
Where is that switch located? I did this same thing yesterday. I had the radio out removing a Bluetooth handsfree module someone else put in
and now when I hit a bump in the road the cluster in the center flickers dim and the exclamation point warning light comes on briefly with a beep.
Return to “G35 and G37 Interior, Exterior and Audio”
