Instrument Panel and Climate Control lights dont work...Part 2
sf_hiphophead
I finally got the chance to take apart the dash and check out the dimmer. I wasnt able to find anything wrong with the wiring, connections, or anything else... Is there a way to check if the dimmer switch itself is broken other than hooking it up to another J30? Does anyone have expirience, directions or pics that might help???
Next I went back and checked ALL the fuses again, and I think I found the problem. The "Glove Box" fuse was blown when the lights first went, so I replaced it (7.5A). When I went back and checked today, it was blown again. So I replaced it (7.5A) again, turned the lights on and... it blew again immediately.
So, I am wondering since it blows right away whether putting a stronger fuse, i.e 10A, might work or if that could fry everything. Or, maybe something on the circuit is putting undue power??? I could give a F about the glovebox light itself, but I have a feeling they're connected.
I REALLY hate going to the dealer, but Im gonna have to real soon if this doesnt get fixed. The majority of the time I drive is at night, of course, and I absolutly love having no idea how fast Im going and how much gas I have... Frustrating is a massive understatment.
PS I have fuses in slots that according to the fuse guide are non-functional (blank)... I assume they cant hurt so i left them but is there any reason extra slots are filled??? Could they have anything to do with this???
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you need to find out why its blowing the fuse. you dont want to put a bigger fuse in there....
Do you have a service manual???
We'll figure tihs out, i really doubt your dealer will help, they hate electrical problem.s theyre only good for problems that the computers can tell them to fix!
xxcrashxx
Car: 95 Infiniti J30
elwesso wrote:theyre only good for problems that the computers can tell them to fix!
kinda like almost all phone tech supports.....
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I emailed you the wireing diagram
elwesso
2007 BMW M Coupe
could you post it up so i could look at it too??? if you cant get it to post, send it to me and ill upload it.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
elwesso wrote:could you post it up so i could look at it too??? if you cant get it to post, send it to me and ill upload it.
Wes I will send you a copy when I get home tonight http://us.a2.yahoofs.com/users...cPgKd
Modified by Gerardjg at 3:30 PM 11/8/2006
Defiant
Car: 1997 J30
sf_hiphophead wrote:I finally got the chance to take apart the dash and check out the dimmer. I wasnt able to find anything wrong with the wiring, connections, or anything else... Is there a way to check if the dimmer switch itself is broken other than hooking it up to another J30?
Did you check it with an ohmmeter?
castlebravo15mt
Car: J30
I had the same problem on my '93. Turns out a small short in the dimmer switch was causing the fuse to blow repeatedly. I had to replace the dimmer and the fuse, and everything's been fine for more than a year now. Picked up a dimmer on ebay for under $10.
Anyone seen the J30 review on this site:http://www.beaterreview.com
Not sure how I feel about my car being a beater, but it's good information.
elwesso
2007 BMW M Coupe
interesting review.... I think 100k is a bit conservative, they dont factor in people who actually take care of the trans by changing the fluid and adding a cooler... And really, you can find the trans pretty dang cheap due to it being shared with the N/A 300ZX.
ayomide86
Car: 1991 Infiniti q45
I replaced a 10A fuse for the instrument panel illimuniation on my 91 Q45 too yesterday and it blew last night as well.Funny thing though is that the light comes on when i apply my brakes. the LED thingy on the instrument panel too reads that my tail lamp and stop lamp are 'inoperable'.
I was going to take the car to a shop to have them check the wiring, but i just read in one of the posts before this one that they don't like doing electrical stuff.
any advice?
yodawill2000
Car: 94 Infiniti J30
castlebravo15mt wrote:I had the same problem on my '93. Turns out a small short in the dimmer switch was causing the fuse to blow repeatedly. I had to replace the dimmer and the fuse, and everything's been fine for more than a year now. Picked up a dimmer on ebay for under $10.
"the fact that it uses components shared with many other Nissan offerings means that parts availability is excellent and prices are quite reasonable."
I want some of whatever he's smokin' LMAO NOT !!
