instrument cluster
A home for 1983–1989 300ZX owners!
masterbbqman
Car: 1987 Nissan 300ZX N/A
okay, so i had no dash lights in my 87 n/a coupe. warning lights all work, just not the lights that actually illuminate the gauges so I can see them at night. pulled the instrument cluster and replaced all the bulbs, still nothing. whats my next move?
masterbbqman
update.... bought a new instrument cluster,plugged it in, till no lights. checked the fog lights, not coming on either. checked the dimmer switch connector for power, nothing there. is there a relay that powers all of this?
bombast
Car: 1985 Nissan 300zx 2+2
2005 Chevy Impala
It sounds like you have the analog dash? I know the Digital Dash lights have an issue because the dash power supplies cable pins needs to be re-soldered on periodically. That worked for me..
masterbbqman
ye analog. trying to find a solution short of a new wiring harness
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
I had the same issue with my digital dash. Turned out to be the headlight switch, if you haven't replaced that then this is probably your problem. Find a new stalk, these seem to be pretty available as about a year ago my mechanic in LA was able to get one quickly.
Return to “300ZX (Z31) Forum”
