instrument cluster problems
arielsdad
I hope someone can help. My instrument cluster intermittently stops working and then after you shut it down for a while it works..
XterraVersa
Car: 2002 Nissan Xterra
Nissan 350Z Nismo
What year & model do you have?
My 02 Xterra did that when new. It turned out to be a loose connection in the fuse block the separated when hot.
chemao
Car: 2019 Tesla Model 3 - preordered
1997V2 AM General H1 with 6.6L Duramax (LML) running biodiesel swap
2015 Lexus CT200H
2003 Hummer H2 with 6.5L Detroit Turbodiesel swap
arielsdad wrote:I hope someone can help. My instrument cluster intermittently stops working and then after you shut it down for a while it works..
I have the same problem. My truck is a 1998 Nissan Frontier XE 2WD with 85,000 miles on it. With such low mileage I can't imagine the gauge cluster is messed up. What mine actually does is all the arrows do wierd things, like the temperagure and fuel gauge just float all the way to the top, and the tach/speedo just sort of bobble around the 8 o'clock position, regardless of my speed. Please help!
madmaxi
Car: 2002 maxima
hi there,its funny because i have a similar problem with my 98' frontier, the big needle which tells you how fast you're going drops all the way down, and the temp, and gas gauge go up past the middle and they start shaking........have you had any new info that you can help me out with?i posted my problem, but nothing yet.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Here's the answer you seek. Sounds like the instrument cluster has packed it in folks, but run through this diagnostic procedure to be sure!
Here's the links so you can print these pages from your own computer.http://is.rely.net/3-47-12409-...g.jpgh ... 8-...A.jpg
