Instrument/Cluster Lights Not Working!?!
iQuABoB
Right now there is a strange problem with my cluster lights:
1) the clock light goes on when the ignition is in acc or on position, but off when the headlights/parking lights are turned on... so it is doing the opposite of what it should be doing
2) the instrument lights will not light up no matter what combination of ignition position, or headlight position i choose... the stuff like abs, ebrake, battery, etc all lights up when the car is in acc or whatever, but the main instrument lights like the ones behind gas, tach, speedo, and temp gauges wont come on...
i have checked fuses... this problem has come about since my deck was stolen and i put the stock deck back in... the stock deck works fine now but the cluster does not work.... at one point the stock deck would reset itself when i turned the lights on, but the cluster would work... now the cluster does not work, but the deck resets itself when i turn the headlights on...
i cannot figure out whats wrong, so if anyone can help i would appreciate it... tia...
U12 2NR
http://www.nissaninfiniticlub....19544
