Instrument cluster lens buzz
General discussion area for the L32-chassis Altima
AltimaJA10
Car: 2010 Alima 2.5 S (SL)
I have 2010 while has developed a soft buzz on moderately rough roads which is coming from instrument cluster. It stops if I lightly touch the lens covering gauges (speedo,tach,etc.). Anyone else have this issue, or an idea on how to fix it? Is it hard to get the lens out to put some thin foam tape on it's edges?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Probably have to screw the instrument cluster down a little more.
AltimaJA10
Wasn't the lens at all but plastic trim below steering column wasn't seated. Pushed panel in to seat it.
Problem solved.
Return to “4th Generation Altima Sedan (2007-2012)”
