Instrument cluster and radio not working..
ilove240sx
Car: 240sx
Could this possible be a relay? I checked all the fuses. I can't even see the speedometer or anything when driving at night. Please help me out! This is my only car.
s13-t
Car: s13 pig nose w/blacktop sr20det
wich fuses did you check? the ones under the hood or the ones in the drivers side kickpanel. My guess would be a fuse behind the kick panel. I have had my cd player loose power to a bad fuse in there. Another culprit could be a gremlin in your dash wiring. check the harness coming from the ecu up to the dash plug. if anythings exposed, fix it.
