instrument cluster and high beam issues
hazeyisrxllin
Car: 2002 q45
2+2 1990 z32 n/a (for sale for the right price)
1990 z32 tt(sold)
1990 z32 tt
2002 q45
2012 xterra 6 speed (granddads car)
2012 xterra auto (grandmas car)
ok so today i install my jensen vx7020 headunit in to my 90 300zx twin turbo and after i hook up the battery the headunit works perfectly but if i turn on my headlights on it automaticly turns on the high beam and the instument cluster wont illuminated any ideas before i attack it in the next few days
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
You probably jumpered to a wrong wire. Try taking the dimmer wire off and see what happens.
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
dimmer wire as in interior lights wire ? and do you think that will fix it
Ace2cool
Yes, the dimmer wire is connected to headlights, so when you turn the headlights on, the head unit dims. If the radio is the only thing you've changed, then the troubleshooting is pretty simple.
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
Yes the radio is the only change I have done but the previous owners did a Butcher job of installing the aftermarker cassette player that was in in before I bought it I played around with it hell I disconnected the radio and the harness wires and was still gettin the same problem
Ace2cool
Double check your fuses and relays. I can't remember which one, but I know I've seen a fuse cause a similar issue. The high beams come on as a "safety" thing or something.
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
Really I'll look into that tommaro I brought my car into work and I was talkin to the older 15 plus year techs atleast those good with electrical all of em said check my relays n schematics on the car there not familiar with nissan there mopar experts but car speaks car so imma look into it more at least I feel better that I wired my radio perfectly first try
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
So I've replaced community illumination and tried the relays from my other z32 and I still have the same issue
Ace2cool
Do you haev HID's by chance?
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
No not yet I was planning to get some soon
Ace2cool
Ok, Just out of curiosity, you didn't happen to hook the radio back up before you swapped relays, did you?
Also, just verify your wiring against this diagram: http://www.nicoclub.com/archives/wiring ... m-z32.html
Usually I see this happen with the illumination wires. I'm talking 90% of the time. If none of that checks out, there may be a problem with the stalk switch, but seeing as the dash is out, I'm betting you've got a wrong wire shorted somewhere.
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
No the radio was still connected and working when I switched the relays I have the bose set up with the center speaker and the scamatics look correct the dash will remain out until my double din face plate shows up now I still had the same problem happend when I disconnected the radio completely and if I'm to use just one illumination wire which do I use
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
As much as I don't want to I'm about to jus have nissan fix it smh
Turbonyg
Car: 1989 Z32 Fairlady
1998 Eagle Talon Tsi Awd
So has this been resolved?
I have an 89 fairlady z32 and driving down a semi bumpy back road this morning, I lost all my cluster and exterior running lights. High beams defaulted to on and signals all continue to work.
I do not have a stereo in the car. Car was gutted when I got it about 2 weeks ago. Driven down this road four times now and this is the first issue. Help would be great. Driving it to work in the morning.
Thanks
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
No I have not solved the issue nissan suggest I install a new harness
Turbonyg
Of course they suggest that. They get paid by the hour.
I just need help on where I should look into this issue. Fuses were
Fine. Gotta check relays tomorrow before I drive it to work but the car has been gutted. I have sensors etc just laying in the hatch area. No stereo, just a hole in the dash...
Any other suggestions besides buy a new harness?
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
Well as for my issue I swapped all the relays from my na z32 I changed the pod with light switch on it I changed the turn signal stalk n I messed with fuses only thing I haven't done is probed my harness
Turbonyg
Fixed my lights and cluster issue tonight. It turned out to be a 20amp fuse below the steering wheel up against the side of the firewall. It looked good and continuity checked good but it was still fried.
Swapped it out and all my lights worked.
1989 300zx tt rhd
Thanks for all your help.
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
Which fuse is it
Turbonyg
Mine was a yellow 20amp atc fuse. Top row of three rows, second from the back of 5 fuses.
Gave me cluster illumination and all my running lights again. I would have to find a fuse block diagram to tell you what it's actually supposed to do.
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
So the second yellow 20a fuse fixed it
Turbonyg
I'll take a photo tomorrow to show you which one.
hazeyisrxllin
Car: 2002 q45
1990 z32 tt(sold)
1990 z32 tt
2002 q45
Ok cool
