Instructions on how to take off 350z emblem and put on Fairlady z
Nissan 350z / Nissan 370z general community discussion forum
murpheyANDthis350z
Car: 2007 nissan 350z pikes peak
Im looking for instructions on how to take off the 350z emblem in the rear and to put on the fairlady Z badge.
dasoupdude
Car: 2005 Nissan 350Z
easy, all u need is
1) Dental floss
2)ICE liquid clay , (or clay bar, but i didn't use one)
3) OOPS or GOOF OFF heavy duty removers. (can buy oops at home depot)
floss off the logo slowly one by one.peel off any leftover adhesive, the difficult ones use the Oops/Goof off liquids to remove the excess adhesive..wet and dry section, -get liquid clay and clay entire section where you see leftover correction fluid marks *press hard with liquid clay on sponge or else you might be able to see the "350z" mark.-dry area -(considering you already taped where the ends go) slap on the emblem and enjoy, (easier if you dont take the foam spacer for the emblem, just unpeal the back stick on then pull the blue foam away. Press hard for about 15 seconds and dont angle out or else it might pop off. sit back and admire your work
Return to “350z / 370z Discussion”
