instruction on how to change driver's side power motor
tracr911
does anyone have instructions or can tell me how to change the driver's side power window motor for a 1993 J30t..??? how to take the door panel off and how to replace the power window motor..? any advice would help !
Modified by tracr911 at 5:29 PM 9/29/2007
gr8scott72
Car: 1994 Infiniti J30t
tracr911 wrote:does anyone have instructions or can tell me how to change the driver's side power motor for a 1993 J30t..???
Power motor what? Seat? Window?
yodawill2000
Car: 94 Infiniti J30
nuk nuk Just what we were chatting about before huh Scott.
Let us know exactly what your needing and we can help you.
liquidJ30
Car: Infiniti J30
if its the window motor which is what i'm guessing your talking about. go to fuzzycats.com ... he has alot of usefull DIY information for the J30. GL!!
zakman
This is from memory so there may be mistakes but it should be pretty much the same.
1. Remove the 4 capped screws on the bottom of the door panel2. Remove doorhandle trim, it may be tricky but be patient and don't bend it. It should slide to the right and then pop out3. pry with your hands at the bottom of the door panel until it pops out, then gently pull so that the top is the only part that is still attached, then jiggle the door panel up and out until it comes out.4. With the door panel off but the connectors still attached, roll the window down to about 3/4's of the way down. Look at where the window itself connects to the track, with two 10mm bolts. Roll the window down until you can access both bolts, one will be accessible through a hole in the sheet metal of the door. 5. disconnect the courtesty lamp connector, power window, etc6. Remove bose speaker, it has 4 or 5 phillips screws, and remove the connector7. Remove the two 10mm bolts which hold the window to the track, and then move the window up and use duct tape to secure it, or remove it completely. 8. Remove all seven 10mm bolts, 4 for the track and 3 for the motor. Leave 1 bolt on each you can just loosen them (youll see which ones they are)9. unplug the connector for the window motor and snake everything out.
Reinstallation is the reverse, should be pretty easy. good luck
