in order for the N1 oil pump to function properly, you need the crank collar fitted/ or extend the snout by another mean.kol wrote:I need some advice and instruction on installing a N1 oil pump to RB25. cheers
Provided it needs it (probably does).BoostFab wrote:in order for the N1 oil pump to function properly, you need the crank collar fitted/ or extend the snout by another mean.
