A Z32 MAF would reduce the amount of intake restriction the stock MAF has. On an engine that injests larger amounts of air than a KA such as the SR I would venture to say that it would net a few hp gain. The downside to running the MAF would be the drop in accuracy a larger MAF gives.msaskin wrote:Upgrading to the Z32 MAF with a T25 won't make a difference. With an upgraded turbo, it's a necessity (other than switching to speed density) since the increased airflow will actually be more than the stock MAF is capable of measuring.
You don't need a re-programmed ECU however, an AFC will do the trick just as well.
~matt
unfrgivn wrote:I decided I'm just gonna make an Intake and do a permanent fix. I thought it was gonna be a lot more, but I think I can do it with...
(2.5"-3") Transistion Silicone Coupler(3") Straight Pipe(3") Straight Silicone Coupler
Hopefully I can orient it coming off the angled inlet to the compressor so that it will clear my power steering lines and what not. If I have to get an angled silicon coupler, they are like $45 which sucks!
