You must have differ visors. The ones from VersaSpeed clearly had instructions to remove the rubber, place the clips, and then put the rubber back. That is with using the adhesive to the outside.marleyfan wrote:You don't actually remove any rubber seal to install the visors. They adhere to the door frame with the 3M tape. The clips clip to the the back end of the front visor and the front end of the back visor and are 3M'd to the door frame. They are just there to provide support to the two ends that meet in the middle of the car since those ends are less supported.
I got mine from Nissan. There must be a difference between the Versaspeed ones and the Nissan ones. At least in the instructions anyway.biggie wrote:You must have differ visors. The ones from VersaSpeed clearly had instructions to remove the rubber, place the clips, and then put the rubber back. That is with using the adhesive to the outside.
I can take pics if needed.
Think the Versaspeed are JDM so could be difference between JDM/USDM.marleyfan wrote:
Yes, he'll ship to Canada. Bob is good.iluvmyVersa08 wrote:Okay, thanks for the help.I'll check out Versaspeed. I live in Canada. Do they ship it out there?Thanks!
Thanks for the help, I'm going to look there. Did you buy them for you Versa?Did you buy them from there? THanks again!yunwoo wrote:iluvmyVersa08:
you can check with this web site http://www.weathertechcanada.c...=2008which is no exterior tape needed, also their showroom is in 516 Parkdale Ave NHamilton, ON, Canada.
The WEATHERTECH visors. I have the fronts only.yunwoo wrote:I am not yet buy it , as it need CAD$200+ after tax for one set.Maybe randyshemin@comcast. would you please, post your Versa. so as we can see how it looks like on our Versa.
Were these hard to install? I watched the installation video from the website, but I don't understand how they stay in the door. Will they affect tinted windows?randyshemin@comcast. wrote:
i agree with you, that is the only reason i do not like that particular set is the fact that they do not cover the small back window. i might end up buying a different set, i want the ones that cover all the windows. i have tinted windows but i still want it to cover the entire door.superskunk wrote:thats the only thing i like about those visors and then thats it... i dont like how the visor for the back door doesnt cover the small window... the visors look really good on a black car with tinted windows.... ill post some pics...
Installation is super easy. Takes just a minute to slip the visor into the window channel. No problem whatsoever. Just follow the simple instructions.iluvmyVersa08 wrote:
